I’ve just done a clean install of Volumio 2.699
RPi 3B+
No DAC
I’m trying to set this unit up for Spotify but I’m not seeing anything in the Plugins menu - not populated at all.
Also System, Check Updates doesn’t find the update server, just hangs till cancelled with OK.
I’m connected via my work lab network
Is there a command line to ping / tracrt the update server?
Also can I force a download of Plugins?
TIA
