Ah, excellent, something to try, thank you :slight_smile:
Ok, so I've booted fresh and then logged in via ssh to check the logs:
-- Logs begin at Fri 2020-09-11 11:27:42 UTC. --
Sep 11 16:09:26 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
Sep 11 16:09:26 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
Sep 11 16:09:26 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Sep 11 16:09:29 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Sep 11 16:09:37 volumio volumio[862]: info: CoreCommandRouter::volumioGetState
Sep 11 16:09:37 volumio volumio[862]: info: CorePlayQueue::getTrack 0
Sep 11 16:09:37 volumio volumio[862]: info: CoreCommandRouter::volumioGetQueue
Sep 11 16:09:37 volumio volumio[862]: info: CoreStateMachine::getQueue
Sep 11 16:09:37 volumio volumio[862]: info: CorePlayQueue::getQueue
Sep 11 16:09:37 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
Then I refresh the volumio.local page and get:
Sep 11 16:12:02 volumio sudo[1584]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Sep 11 16:12:02 volumio sudo[1584]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 11 16:12:02 volumio sudo[1586]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Sep 11 16:12:02 volumio sudo[1586]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 11 16:12:02 volumio sudo[1584]: pam_unix(sudo:session): session closed for user root
Sep 11 16:12:02 volumio sudo[1586]: pam_unix(sudo:session): session closed for user root
Sep 11 16:12:03 volumio sudo[1606]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Sep 11 16:12:03 volumio sudo[1606]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 11 16:12:03 volumio sudo[1608]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Sep 11 16:12:03 volumio sudo[1608]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 11 16:12:03 volumio sudo[1606]: pam_unix(sudo:session): session closed for user root
Sep 11 16:12:03 volumio sudo[1608]: pam_unix(sudo:session): session closed for user root
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::volumioGetState
Sep 11 16:12:04 volumio volumio[862]: info: CorePlayQueue::getTrack 0
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::volumioGetVisibleSources
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Sep 11 16:12:04 volumio volumio[862]: info: Listing playlists
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
Sep 11 16:12:04 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Sep 11 16:12:06 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Then when I click on Plugins I get:
Sep 11 16:14:18 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: my_volumio , detectVolumioHardware
Sep 11 16:14:19 volumio volumio[862]: info: Could not detect Volumio Device: Error: Command failed: aplay -l | grep es90x8q2m-dac-dai-0
Sep 11 16:15:19 volumio volumio[862]: info: Cannot download Available plugins list: Error: socket hang up
If however I then click on web radio and pick one from random, it plays and the log shows:
Sep 11 16:16:13 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Sep 11 16:16:13 volumio volumio[862]: info: CoreCommandRouter::volumioGetQueue
Sep 11 16:16:13 volumio volumio[862]: info: CoreStateMachine::getQueue
Sep 11 16:16:13 volumio volumio[862]: info: CorePlayQueue::getQueue
Sep 11 16:16:23 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Sep 11 16:16:33 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Sep 11 16:16:33 volumio volumio[862]: info: TuneIn handleBrowseUri: tunein/local
Sep 11 16:16:42 volumio volumio[862]: info: CoreCommandRouter::volumioReplaceandPlayItems
Sep 11 16:16:42 volumio volumio[862]: info: CoreStateMachine::ClearQueue
Sep 11 16:16:42 volumio volumio[862]: info: CoreStateMachine::stop
Sep 11 16:16:42 volumio volumio[862]: info: CoreStateMachine::setConsumeUpdateService undefined
Sep 11 16:16:42 volumio volumio[862]: UNSET VOLATILE
Sep 11 16:16:42 volumio volumio[862]: info: CorePlayQueue::clearPlayQueue
Sep 11 16:16:42 volumio volumio[862]: info: CorePlayQueue::saveQueue
Sep 11 16:16:42 volumio volumio[862]: info: CoreCommandRouter::volumioPushState
Sep 11 16:16:42 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Sep 11 16:16:42 volumio volumio[862]: info: CoreCommandRouter::volumioPushQueue
Sep 11 16:16:42 volumio volumio[862]: info: CoreStateMachine::addQueueItems
Sep 11 16:16:42 volumio volumio[862]: info: CorePlayQueue::addQueueItems
Sep 11 16:16:42 volumio volumio[862]: info: Adding Item to queue: http://opml.radiotime.com/Tune.ashx?id=s105824
Sep 11 16:16:42 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: webradio , explodeUri
Sep 11 16:16:43 volumio volumio[862]: info: CorePlayQueue::saveQueue
Sep 11 16:16:43 volumio volumio[862]: info: CoreCommandRouter::volumioPushQueue
Sep 11 16:16:43 volumio volumio[862]: info: CoreStateMachine::updateTrackBlock
Sep 11 16:16:43 volumio volumio[862]: info: CorePlayQueue::getTrackBlock
Sep 11 16:16:43 volumio volumio[862]: info: CoreCommandRouter::volumioPlay
Sep 11 16:16:43 volumio volumio[862]: UNSET VOLATILE
Sep 11 16:16:43 volumio volumio[862]: info: CoreStateMachine::play index 0
Sep 11 16:16:43 volumio volumio[862]: info: CoreStateMachine::setConsumeUpdateService undefined
Sep 11 16:16:43 volumio volumio[862]: info: CoreStateMachine::stop
Sep 11 16:16:43 volumio volumio[862]: info: CoreStateMachine::play index undefined
Sep 11 16:16:43 volumio volumio[862]: info: CorePlayQueue::getTrack 0
Sep 11 16:16:43 volumio volumio[862]: info: CoreStateMachine::startPlaybackTimer
Sep 11 16:16:43 volumio volumio[862]: info: [1599841003384] ControllerWebradio::clearAddPlayTrack
Sep 11 16:16:43 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand stop
Sep 11 16:16:43 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand clear
Sep 11 16:16:43 volumio volumio[862]: ---------------------------- MPD announces system playlist update
Sep 11 16:16:43 volumio volumio[862]: info: Ignoring MPD Status Update
Sep 11 16:16:43 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand load "http://stream.amazingradio.com:8000/stream.mp3"
Sep 11 16:16:43 volumio volumio[862]: error: updateQueue error: null
Sep 11 16:16:43 volumio volumio[862]: info: ------------------------------ 71ms
Sep 11 16:16:46 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand add "http://stream.amazingradio.com:8000/stream.mp3"
Sep 11 16:16:46 volumio volumio[862]: info:
Sep 11 16:16:46 volumio volumio[862]: ---------------------------- MPD announces system playlist update
Sep 11 16:16:46 volumio volumio[862]: info: Ignoring MPD Status Update
Sep 11 16:16:46 volumio volumio[862]: info: CoreStateMachine::setConsumeUpdateService mpd
Sep 11 16:16:46 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand play
Sep 11 16:16:46 volumio volumio[862]: info: ------------------------------ 61ms
Sep 11 16:16:46 volumio volumio[862]: ---------------------------- MPD announces state update: player
Sep 11 16:16:46 volumio kernel: pcm512x 1-004d: No SCLK, using BCLK: -2
Sep 11 16:16:46 volumio volumio[862]: info: ControllerMpd::getState
Sep 11 16:16:46 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand status
Sep 11 16:16:47 volumio volumio[862]: ---------------------------- MPD announces system playlist update
Sep 11 16:16:47 volumio volumio[862]: info: Ignoring MPD Status Update
Sep 11 16:16:47 volumio volumio[862]: ---------------------------- MPD announces state update: player
Sep 11 16:16:47 volumio volumio[862]: info: ControllerMpd::getState
Sep 11 16:16:47 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand status
Sep 11 16:16:47 volumio volumio[862]: verbose: ControllerMpd::parseState
Sep 11 16:16:47 volumio volumio[862]: verbose: ControllerMpd::sendMpdCommand playlistinfo
Sep 11 16:16:47 volumio volumio[862]: info: ------------------------------ 116ms
Sep 11 16:16:47 volumio volumio[862]: verbose: ControllerMpd::parseTrackInfo
Sep 11 16:16:47 volumio volumio[862]: info: ControllerMpd::pushState
Sep 11 16:16:47 volumio volumio[862]: info: CoreCommandRouter::servicePushState
Sep 11 16:16:47 volumio volumio[862]: info: CorePlayQueue::getTrack 0
Sep 11 16:16:47 volumio volumio[862]: verbose: STATE SERVICE {"status":"play","position":0,"seek":470,"duration":0,"samplerate":"44.1 kHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"bitrate":"128 Kbps","isStreaming":false,"title":"Amazing Cast","artist":"Amazing Cast","album":null,"uri":"http://stream.amazingradio.com:8000/stream.mp3","trackType":"mp3"}
Sep 11 16:16:47 volumio volumio[862]: verbose: CURRENT POSITION 0
Sep 11 16:16:47 volumio volumio[862]: info: CoreStateMachine::syncState stateService play
Sep 11 16:16:47 volumio volumio[862]: info: CoreStateMachine::syncState currentStatus stop
Sep 11 16:16:47 volumio volumio[862]: info: CoreStateMachine::pushState
Sep 11 16:16:47 volumio volumio[862]: info: CoreCommandRouter::volumioPushState
Sep 11 16:16:47 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Sep 11 16:16:47 volumio volumio[862]: info: ------------------------------ 452ms
Sep 11 16:16:47 volumio volumio[862]: verbose: STATE SERVICE {"status":"play","position":0,"seek":493,"duration":0,"samplerate":"44.1 kHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"bitrate":"128 Kbps","isStreaming":false,"title":"Amazing Cast","artist":"Amazing Cast","album":null,"uri":"http://stream.amazingradio.com:8000/stream.mp3","trackType":"mp3"}
Sep 11 16:16:47 volumio volumio[862]: info: CoreStateMachine::syncState currentStatus play
Sep 11 16:16:47 volumio volumio[862]: info: Received an update from plugin. extracting info from payload
Sep 11 16:16:47 volumio volumio[862]: verbose: STATE SERVICE {"status":"play","position":0,"seek":586,"duration":0,"samplerate":"44.1 kHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"bitrate":"112 Kbps","isStreaming":false,"title":"Amazing Cast","artist":"Amazing Cast","album":null,"uri":"http://stream.amazingradio.com:8000/stream.mp3","trackType":"mp3"}
Sep 11 16:16:47 volumio volumio[862]: info: ------------------------------ 846ms
Sep 11 16:16:47 volumio volumio[862]: info: ------------------------------ 810ms
Sep 11 16:16:49 volumio volumio[862]: info: VolumeController::SetAlsaVolume30
Sep 11 16:16:49 volumio volumio[862]: info: CoreStateMachine::pushState
Sep 11 16:16:49 volumio volumio[862]: info: CoreCommandRouter::volumioPushState
Sep 11 16:16:49 volumio volumio[862]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Does that show anything useful??
