Greetings, I have updated to Volumio 3, and I have purchased a premium account, but it does not appear in the add-ons, Qobuz, can you tell me where and how I can install it. Thank you
It’s built in - you will find the Qobuz login a bit down on the sources page.
You will find it under “Sources” normally…
For me, it didn’t show up right away when I upgraded to Volumio 3. When I first checked, I saw the Tidal option (which I don’t use) but not Qobuz. But after several minutes (or possibly from jumping around from one screen to another), Qobuz did show up. And it works really well!
