No playback when put Pontus 2 in place of SMSL D2R worked totally fine with D2R on both Roon and Volumio Playback
Volumio 3 Issues?
I am using Volumio 3 free. I used it with a SMSL D2R DAC and it worked perfectly on playback with my Synology NAS and also worked perfectly with ROON. I changed the SMSL D2R dac out to a DEnafrips Pontus 2 dac. I changed the DAC in Playback choice Volumio to the only one it showed and it played with Volumio again no issues. But in Roon when I select the same output as in the Volumio one I chose that works it say Device not found and it will not play with Roon now. I installed my Rock based endpoint and that plays fine with Roon.
