on both my RPi3B+ and my Allo USBridge Signature Player (I’m not trying both at the same time, this is just to show that it seems device independent), I observe the following behavior:
- Fresh install of Volumio from downloaded .img
- Integration in home network
- Login to myvolumio, activation of device
- Tidal (directly on Volumio) works fine after login
- Tidal Connect, however, does not. When I initiate the connect from the iOS Tidal app, Volumio shows a notification about a new connection. However, hitting play on the iOS app yields… nothing.
Help please?
