Everytime I use my Android tablet to connect my Pi4 running Volumio, it ask me do I want to connect with Bluetooth.
Is there way I can disable the Bluetooth on Volumio?
Hi, search for Nerd’s Flight Mode plugin in Plugins section.
Thanks!
I saw that and I was under impression it will turn off both wifi and Bluetooth together, like phone airplane mode.
And I was under the impression that Bluetooth stays off when it’s disabled in settings (I have that yellow warning from the Android app too), so now I’m going to install this plugin as well.
Official documentation — not always concise, sometimes outdated — is arguably this project’s weakest point; you’ll often have to dig through the forums to find what you need. On the other hand, a vibrant and inventive community is its strongest point.
Without that, this would be a very different experience. So a shout-out to all community contributors and Plugin Wizards — we
you!
Hi Wilson,
it’s a known issue in Volumio OS 4 with recent Android devices that support LE Audio.
The fix is in the next Volumio OS 4 release, coming soon. Update the Pi once it’s out.
Until then, the Flight Mode plugin works around it: with Bluetooth off the prompt can’t appear, and the app keeps working over your network.
