As in subject, updated last software, no solution. Can’t see the interpret in “kmih” broadcasting. Always the same since 11/² weeks above? On other broadcastings it works but after the softwareupdate I have only squares instead of symbols in the upper line?
It could well be they simply don’t send the audio metadata with the stream. If the same stream works with an older version, then we might have a regression there
