I have a small problem which I can not solve alone:
on my Raspberry Pi 2 with a 7" Raspberry Pi touch screen I can get no user interface.
I can see only the terminal input.
The touch screen is functioning good because I can see a “Volumio” splash screen on booting and then I see only the terminal input.
The system is functioning somehow because I can hear the Volumio boot “gingle”
Everything is ok. Volumio is designed to be headless. You have to access it from a other device on the same network (smartphone, computer).
Once you are connected to the webUi, install the plugin for the touch screen. And you will have a functional touch screen.
Have a look https://volumio.github.io/docs/
Did the plugin install OK without any errors? Can you see the UI in a browser on another device? Try reinstalling, and if that fails then send us a log to have a look at (don’t forget to post link to log here).
