I am trying to setup a new install of Volumio and have a Veolumio Virtuoso (trial) plan to use Tidal.
i dont see my device, even though i have logged in to myvolumio on the host.
another issue i have, is that i see no plugins under “search” nor “installed”
Login into myvolumio on your device, then go to profile. After a couple of seconds you should see your device appear.
You will find TIDAL under my music section
