I updated my Volumio for RaspberryPi to 2.799 from the June version, and now I get an error on the NAS connection.
It seems to mount, but the library database is 0 and won’t be updated.
The log shows an error “No database”.
It worked fine in the previous version.
info: CoreCommandRouter::executeOnPlugin: networkfs , addShare
info: Adding a new share
info: No correspondence found in configuration for share CifNAS on IP 192.168.0.x
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t cifs -o guest,ro,dir_mode=0777,file_mode=0666,iocharset=utf8,noauto,soft,vers=2.1 //192.168.0.x/music /mnt/NAS/CifNAS
info: [1595378256346] Database scan error: Error: Command failed: /usr/bin/mpc update
error: No database
