No connection Spotify to Rivo through Spotify connect only via airplay
The last 3 weeks I can not connect Spotify (premium) to Rivo.
only through airplay and of course when the phone is ringing the music stops!!!
There is no icon in my Iphone to show Spotify connect , there is only the icon of Rivo and when I try this to connect , there this no connection . On the other hand my Tidal is connected to Tidal connect .
I am facing so many troubles with the connections , since the moment I purchased Rivo ( two years ago.
I am pist off . I will resell my Rivo if this will not be solved the next days, in a very low price in oder to get rid of it .
Thank you !!!
did you update the Spotify plugin to the latest version?
