Hi
I installed Volumio on sd card for Raspberry pi.
For the first start everything works. But after the first reboot, I cannot see my volumio anymore. (by web interface or MPod app).
Sometimes I can pinging the device works.
If I flash the sd card again it works till the next reboot.
I tested on two different Raspis. The same issue.
With the previous version (raspyfi) there was no problem.
My Raspi had the same symptoms but the cause was the powersupply: the cable used to connect the Pi and the power supply was not good enough. (It works well with other equpment but not with the Pi).
So, after powering up with a better power cable, Volumio booted and rebooted as it should.
