so I have Volumio 3 on a raspberry Pi, brand new install. My music is on a Synology NAS on the same LAN, both are connected by ethernet and have a static IP. Connections to each are solid.
So I make the music folder an NFS share and after a bit of fiddling I could mount it in Volumio and then get the library scanned.
Then I map the same folder to my laptop (windows 10). I create a new “tmp” folder in music and drop a wave file in.
In Volumio I am initially able to browse to the file and play it. This is something I really need to work (it’s the whole point of having a NAS), so good so far.
Now 10 mins later - Volumio suddenly sees no files and the entire library database seems to be empty.
This doesn’t look good …
