NFS server mount
I am trying to mount my network NFS mount without success.
This is a Pi installation and tried Volumio 2 plus the test beta. Fixed the IP address OK, is there any information you need to debug? I know the NFS server is OK because it works perfectly in 1.55.
Steve
I have made a little progress with this. Volumio 2 appears to be changing the path.
In 1.55 for my set up that works it is 192.168.1.7/e/music
In version 2 the path comes out as 192.168.1.7:e/music.
Is there a way to swap the : for a / after the IP address?
Steve
