Dear Masters of Volumio,
I have been using the Trio Volumio, RPI 512A (or B?) and my Cambridge Audio DacMagic for many years now without any problems. Last version of Volumio I used was 2.224.
Now I thought it is time for an update and I downloaded and installed V2.555 on a fresh SD-Card. I started the RPI with the new Version while my DacMagic was running already (as usual) in order that the RPI detects the DacMagic.
Unfortunately, it doesn’t work. If I try to change the output, I strangely don’t get “USB Audio” as an output option anymore, but “USB: C-Media USB Headphone set”. The other two output options are as previously “Audio Jack” and “HDMI Out”. see attachment:
I put the old SD-card in with Volumio 2.224 and everything works fine again with the output selected to “USB Audio”.
Has anyone an idea what’s wrong here? I searched for a solution now already many evenings and have no idea anymore what to do.
Thanks in Advance!
Your Volumio addicted perfect_day
PS: screenshot attached with V.2555 shows my Audio output options - no USB Audio anymore
