They are a small team, and are super busy since May! Plus they have new hardware to launch…
If only there was an older working connect plugin they could revert to while this one is being made perfect… especially for people who prefer control from Spotify’s apps…
I second that, @volumio did a great job urgently fixing it so that it is at least working!! Also Pandora, web radio, mpd, Tidal, qobuz all seem to be working well and Manifest UI is now free. Awful lot of integrations for a free service!!
Thanks @Steve1 , you are correct, "awful lot of” is an English phase for very good. Sorry for the inconsiderate use of the English centric phrase. All intentions were intended to be positive.
Hi, sorry is this plugin working ?
my problem ist cant start the songs /
my logfile:
info: CoreCommandRouter::volumioPlay
info: CoreStateMachine::play index undefined
info: CorePlayQueue::getTrack 7
info: CoreStateMachine::startPlaybackTimer
info: [1667767961793] ControllerSpotify::clearAddPlayTrack
info: Setting this device active
error: Failed to Set Device Active: Error: Not Found Device ID: 74fe1144089a442250910ee4d2ffbc0e5f6e3058
A clean install of Volumio 3.378, plugin is 3.0.6. Spotify Connect starts playing from my mobile phone but after 5…10…15 minutes stops. At this moment I can’t find VOLUMIO in the device list, it becomes availale after few minutes and then I can start playing again. What should I do to get stable work?
Hi everyone, I have 4 x R Pis and using the latest Spotify plugin.
I have a premium Spotify account, and each player has their individual logon to Spotify.
They play a playlist and are set to repeat playlists, so an infinite loop.
The players will last about a day playing the playlist, then just stop. Some need to restart, some need the plugin turned off, then logged back into Spotify, then find the playlist, hit play and repeat, and it works for another day or so.
Is there any work around or way to reboot them daily and play the last playlist?
I agree that non working plugin should be removed from stable branch of plugin manager after a couple of weeks, it would make things more transparent and understandable, furthermore for service not officialy supported
For ALL the rest covering all complaints of volumio non working service, as a temporary solution at least, just install dstmmix from beta plugin store, install local player plugin within LMS to connect your soundcard to LMS end enjoy a fully reliable music renderer with absolutely every music service that exist working like a charm including local file, radios and spotify/tidal/Qobuz
In addition you will get smart playlist,automation, multiroom, chromecast bridge, music on start … with never a crash !!
