New plugin causes failure when starting up (after fresh install)
Hello. I am developing a new plugin using the latest bookworm repo as a base.
The index.js of the plugin starts a http server, which severs static html/js app (made using React in a separate repo).
These are the steps I am following to install the plugin:
  1. SSH to Volumio
  2. Get latest branch / commits from my forked bookworm repo
  3. cd into the plugin directory of the repo locally on Volumio
  4. running “volumio install plugin”
The install process seems to go fine without issues but the plugin causes Volumio to not start and I see errors in the logs
Mar 16 18:42:23 volumio volumio[274404]: error: The plugin user_interface/stylish_player failed to load, setting it to stopped. Error: Error: Cannot find module '/data/plugins/user_interface/stylish_player/node_modules/kew/kew.js'. Please verify that the package.json has a valid "main" entry
Mar 16 18:42:23 volumio volumio[274404]: error: Stack trace: Error: Cannot find module '/data/plugins/user_interface/stylish_player/node_modules/kew/kew.js'. Please verify that the package.json has a valid "main" entry
The only way to make it work is to delete the node_modules + package-lock.json file from the /data/plugins/user_interface/my_plugin directory and npm install again.
After that everything works fine.
I am wondering if I am missing anything in the install.sh file.
#!/bin/bash
echo "Installing Stylish Player Dependencies"
cd /data/plugins/user_interface/stylish_player
echo "Installing node dependencies"
npm install --production
echo "Stylish Player plugin installed"
echo "plugininstallend"
uninstall.sh doesn’t do anything yet. Wondering if I need to manually delete node_modules and package-lock.json in this file.
#!/bin/bash
echo "Uninstalling Stylish Player"
echo "Done"
echo "pluginuninstallend"
