New Install - Can't connect to Wifi
The ‘volumio2’ password doesn’t work on the volumio-2.729-2020-03-18-pi image. I tried an iPhone, MacOS and Windows10 when connection to the ‘Volumio’ wi-fi network. None connect.
Ideas?
Same issue here. I did not get connected to the Hotspot. Still after Wifi Setup via Cable Lan, the Wifi was totally instable and stopped working suddenly.
Finally I took an old image (volumio-2.452-2018-08-27) and it works without any issues.
older-volumio-versions-img-files-t7009.html
I use Raspberry Pi2 with Edimax EW-7811 Wifi Dongle .
As just seen there is also a bug report at GitHub about that problem. Was there any change in Wifi sections?
github.com/volumio/Volumio2/issues/1924
