I changed my Audiophonics ES9038 by the Waveshare WM8960.
I installed the module from github.com/waveshare/WM8960-Audio-HAT on my RPI3.
Of course the install didn’t work well on Volumio
and the soundcard doesn’t play AT ALL.
The same installation process on Raspbian works perfectly with VLC & VLC Remote from my phone.
Unfortunately, VLC is a little bit raw.
I did a lot of research on Linux (forums) but couldn’t find any solution.
Sound on Linux is quite fiendly.
Is there any idea ?
The Wolfson WM8960 is a device for portable use or for games consoles (‘portable digital audio applications’) and the spec is appropriate to that use-case. ‘DAC SNR 98dB (‘A’ weighted), THD -84dB at 48kHz, 3.3V’ is dreadful by comparison to a TDA1541 (found in ApplePi DAC and others, 112dB and -95dB). To jump from ESS9038 to WM8960 is an act of bravery re your hearing, so that board must be doing something else for your particular instance…
Before the run of the kernel driver installer script (instal.sh) run the following command:
sudo volumio kernelsource
To make the IS2 work insert the following line in /volumio/app/plugins/system_controller/i2s_dac/dacs.json after the {“name”:“Raspberry PI”,“data”:[ line
Hi nakamishi
flashed Volumio 2.882 an an SD and then followed your description (kernel source) and then tried to install the drivers.
Received error messages referring to missing gcc (see message below)
I see your messages distributed over different questions. It looks like you made this card work under Volumio.
Would it be possible to have a list of steps how to patch the kernel / change settings …?
Would help a lot!
Thank you and kind regards
(A long time a go I had a Nakamishi BX-100 :-))
Error Message:
The following packages have unmet dependencies:
dkms : Depends: gcc but it is not going to be installed
Recommends: linux-headers-686-pae but it is not installable or
linux-headers-amd64 but it is not installable or
linux-headers-generic but it is not installable or
linux-headers
