I’m testing Volumio on a RPi 4B 4Gb with a view to adding an Allo Digione Signature if Volumio (2.673) is reliable and stable.
Although my initial impressions of Volumio were good, I am having a problem with it regarding the network connection. I have the Pi connected directly to my TP Link router via ethernet. After booting up, Volumio works via my Android phone (although I have to connect via IP address rather than volumio.local). I noticed that after a while that I’m not able to connect back to Volumio and end up having to power cycle. I have tried setting static IP address in Volumio, and in my router. Although both methods work, if I disconnect the ethernet cable and reconnect it, more often than not Volumio will not reconnect and I end up having to power down.
I have also tried enabling WiFi, and again, if the Wifi connection is lost, Volumio won’t reconnect. A bit of Googling reveals that this problem seems fairly common.
Any ideas if there’s a fix ?
