Hello chsims1. I really appreciate the time you are dedicating.
As you advised me, I’ve made a system log. The results can be found in the following link:
http://logs.volumio.org/volumio/xjQrUuw.html
I’ve also accessed to the command line of Volumio via SSH (I’ve used openssh), and these are the results:
Command “mount”:
volumio@volumio:~$ mount
/dev/mmcblk0p2 on /imgpart type ext4 (rw,relatime,stripe=1024,data=ordered)
/dev/loop0 on /static type squashfs (ro,relatime)
overlay on / type overlay (rw,relatime,lowerdir=/mnt/static,upperdir=/mnt/ext/dyn,workdir=/mnt/ext/work)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
devtmpfs on /dev type devtmpfs (rw,nosuid,size=485032k,nr_inodes=121258,mode=755)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,noexec)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=22,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,noatime,mode=755)
tmpfs on /var/spool/cups type tmpfs (rw,noatime,mode=755)
tmpfs on /var/log type tmpfs (rw,nodev,relatime,size=20480k,mode=777,uid=1000,gid=4)
tmpfs on /var/spool/cups/tmp type tmpfs (rw,noatime,mode=755)
/dev/mmcblk0p1 on /boot type vfat (rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
rpc_pipefs on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
//192.168.1.1/samba\usb1_1 on /mnt/NAS/musica type cifs (ro,relatime,vers=1.0,sec=none,cache=strict,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.1.1,file_mode=0666,dir_mode=0777,soft,nounix,mapposix,rsize=61440,wsize=65536,echo_interval=60,actimeo=1)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=99412k,mode=700,uid=1000,gid=1000)
volumio@volumio:~$
Commmand “ls /mnt/NAS/musica”:
volumio@volumio:~$ ls /mnt/NAS/musica
ls: cannot access /mnt/NAS/musica/-: No such file or directory
ls: cannot access /mnt/NAS/musica/A: No such file or directory
ls: cannot access /mnt/NAS/musica/B: No such file or directory
ls: cannot access /mnt/NAS/musica/D: No such file or directory
ls: cannot access /mnt/NAS/musica/E: No such file or directory
ls: cannot access /mnt/NAS/musica/G: No such file or directory
ls: cannot access /mnt/NAS/musica/K: No such file or directory
ls: cannot access /mnt/NAS/musica/M: No such file or directory
ls: cannot access /mnt/NAS/musica/O: No such file or directory
ls: cannot access /mnt/NAS/musica/R: No such file or directory
ls: cannot access /mnt/NAS/musica/T: No such file or directory
ls: cannot access /mnt/NAS/musica/C: No such file or directory
ls: cannot access /mnt/NAS/musica/F: No such file or directory
ls: cannot access /mnt/NAS/musica/H: No such file or directory
ls: cannot access /mnt/NAS/musica/I: No such file or directory
ls: cannot access /mnt/NAS/musica/J: No such file or directory
ls: cannot access /mnt/NAS/musica/L: No such file or directory
ls: cannot access /mnt/NAS/musica/N: No such file or directory
ls: cannot access /mnt/NAS/musica/P: No such file or directory
ls: cannot access /mnt/NAS/musica/S: No such file or directory
ls: cannot access /mnt/NAS/musica/U: No such file or directory
ls: cannot access /mnt/NAS/musica/V: No such file or directory
- - - - - - - A B B B B B C C D D E E F G J K L L M M M N N O P R S S T T T T T T T T V V
- - - - - - - A B B B B C C D D D E E F G J K L L M M M N N O P R S T T T T T T T T T V V
- - - - - - - A B B B B C C D D D E E G G J K L M M M M N N O R R S T T T T T T T T U V V
- - - - - - A A B B B B C C D D E E F G H J K L M M M N N O P R S S T T T T T T T T U V
- - - - - - A B B B B B C C D D E E F G I K L L M M M N N O P R S S T T T T T T T T V V
volumio@volumio:~$
I have to admit that all these code seems quite confusing to me.
I hope these result useful to you.
Thank you very much.
