Volumio Version: 2.873 (also seen with Buster Beta 3.066)
Hardware: RPi 3B
DAC: Hifiberry AMP2
I’m using a python script running on another device using the socketio library to control Volumio, it’s working well but but I’m having trouble getting a track to continue from the same position after pause.
If I use the Web UI all works as expected - track is playing, click pause, the song stops, press play, the song starts again where it left off.
But from the Websocket API I can’t replicate this behaviour.
Example: Track is playing:
emit(‘pause’, {} )
then emit(‘play’, {‘value’:0} )
Track starts from the beginning not where it stopped
I tried using ‘seek’, this works if the track is playing for example with the track playing:
emit(‘seek’, 60)
Status from pushStatus, ‘seek’ changes to 60000
Track jumps to the 60 second mark and continues
But if the track is paused:
emit(‘seek’, 60)
Track starts at the beginning again
Any help would be appreciated, have to say the documentation for the API is not the easiest to follow
Just emit play without value, since it does not need any parameters, my best guess is that when you emit value=0 it starts playback of first song in queue and from beginning obviously.
Thanks for the suggestion - you were correct.
I’ve just tested again and the following all work, restart paused track at last position
emit(‘play’, )
emit(‘play’, ‘’)
emit(‘play’, {} )
emit(‘play’, 0 )
But, as you suspect emit(‘play’, {‘value’: 0} ) restarts at the beginning
