Need help with NanoSound One with Raspberry Pi 4B
I got a NanoSound One and hooked up my Raspberry Pi 4B to it. There are issues with the sound, there is just noise coming out, so I have some questions.
Should it work with 4B or only the 4 version of Raspberry Pi?
What is the model of the HiFi board?
I used the Volumio image from here: https://nanomesher.com/support/nanosound-support/. Looks like it’s for the NanoSound 2, which is different. I downloaded the plugin for NanoSound One there, but what should the playback configuration be? I tried HiFiBerry Plus and it’s still not working.
Also, how do I get HDMI to work with it, is it with a converter switch to RCA? What about the settings?
Is there anything that you can suggest?
Alex
