Ned Help with Plugin Backup & Restore Data
Hi, i installed the plugin for backup and Restore from @macmpi.
github.com/macmpi/volumio-plugi … up_restore
But i don´t understand where the backup file is.
They said it is saved on smb root. What does it mean? My NAS is read only for all users without admin.
I have checked with an external usb stick but nothing.
Please help for an newbie. i don´t want allways backup the complete SD Card.
It is saved on a samba share called “Internal Storage” on the RPi. You can either connect to it directly via Windows, or ssh into your device and copy it to a usb stick or use “scp” to transfer to another networked device.
Thx @chsims1
I found the file via Windows -> Network -> Volumio.
But not in winscp i am always in the root file folder without a internal Storage file folder. Maybe i have to change something?
Sounds like you are not actually logged onto your device.
if you log in through SSH or equivalent, file path is: /data/INTERNAL/volumio_data.tgz
