Volumio Information
Player Name: Volumio Listening Room
Volumio Version: 2.806
Hardware: pi4 4GB
DAC:HiFiBerry DAC+ Pro
Player Name: Volumio 2BR
Hardware Pi 3B
DAC: HiFiBerry AMP2
Player Name: Volumio 3
Volumio Version: 2.799
Hardware Pi 3B
DAC: HiFiBerry AMP2
Here’s the problem. I have an SSD drive attached to the USB port on “Volumio Listening Room”
It is mounted as a NAS on the other two systems. On “Volumio 3” it shows up with all of the contents. On “Volumio 2BR” it shows up but contents display “No Items”.
The only difference I can account for between these two systems is the Volumio version. It did not display any error when I set up the NAS in Sources on “Volumio 2BR”. I tried doing a restart to see if it would pick up but no change.
It was working prior to the Volumio update to 2.806. I can play web radio content fine on all three players.
What can I check / edit to make the NAS playable from “Volumio 2BR”?
I can post logs if needed but there will be a lot with the three systems.
Steve
