Normally a happy Volumio user but this is very weird.
Had my system down for 3 months for upgrading my dac.
When setting up Volumio again (after upgrading to 2.389) with all the info like network and music I got this strange warning and was unable to reach the NAS with Volumio, I can reach it through another pc though through the same wired network
I hope I can take care of this without getting into Linux because I do not no anything about it.
Also try vers=2.0 or vers=3.0 or vers=3.1
In that order, we do not know yet how to solve this without manual intervention after the cifs security has been hardened.
Nope, not possible. The PI kernel used for building Volumio has an updated CIFS module for improved security and performance.
SMB3 is the now the default dialect, we do not get to choose this other than overriding it with a mount option âvers=â.
âwhat ifâ is for pessimists
Iâm convinced it is just that, you could of course check your NAS/ server to see what versions of SMB has been configured.
In case it is 1.0 or 2.0, then there you have it.
Btw. for 3.0 (and 3.1) you should not have to add âvers=â, my mistake.
Iâm sort of a realistic person and at this point, Iâm sad to say, correct in my assumptions as it does not work.
The only version which âworksâ in my case is vers=1.0
It begins with all the right messages in my app screen that the NAS is mounted (2.34TB) the library is being read and you see tracks/artists/albums coming in the libraryâŠ
So far so good.
After 30 min. or so the green led on the Pi is not flashing randomly anymore but lit up constantly .
This happens just about the point that âartistsâ reaches the 1000 mark. Is there a limit to the number of artists perhaps or in my case?
I lose connection with Volumio via app or pc, if I play music it begins to stutter and eventually it crashes, sort of.
After again 30 min. or so this crash evaporates and Iâm able to get in Volumio.
The NAS is mounted, box ticked with green but no musiclibrary, nothing, zilch, nada.
So, what if
EDIT: found a very crude manner to work around the problem, it isnât solved though :ugeek:
Just before I think the Pi/Volumio freezes I shut it down. The library read to that point is saved so I can play music for now because thatâs what I like :mrgreen:
You might want to search the forum or open a separate thread for your library problem as this has no relation with the CIFS issue.
I donât think there is a limit, but there may be others who know more about it.
Hi there gkkpch, as a hifi nutter I think I owe you and Volumio an apology for my musiclibrary problems
I became frustrated last night and looked more closely at my network and NAS. I found 2 firmware updates for my NAS and made a different setup on my music network.
Musiclibrary was read without a hick up
So nothing wrong with the new software release, it was just me, sorry
Just had an issue getting an Integro to connect to my NAS (which my RPi base Volumio can access). Got it working by entering âvers=3.0â in the options field. Maybe this will help others.
