I’m using Volumio 2.041, on RP Raspbian GNU/Linux 8 (jessie), Linux 4.4.9-v7+ armv7l, headphone jack (no DAC), 8GB SD. Music files are on WD MyCloud NAS, firmware v04.04.05-101. Both are connected to the same router via Ethernet. NAS has static IP address.
Volumio finds the NAS and mounts it (using cifs). It scans files when I go to My Music and hit Rescan. It finds files OK, but then when it’s done, it does not save the result. If I navigate away and then come back later Volumio reports 0 artists, 0 albums, 0 tracks. I can see these numbers go up when scanning, but the result is never saved.
I have tried rebooting all devices. I even reflashed a new image of Volumio and started from scratch. There is nothing marked as an error in /var/log/volumio.log. Tail of log is
2017-01-27T21:08:02.646Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:06.633Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:10.641Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:14.653Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:19.640Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:22.662Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:26.573Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:30.639Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:34.650Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2017-01-27T21:08:38.642Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
I have no idea how to troubleshoot this. I would like to use Volumio, but this is a showstopper. Does anyone have any advice or suggestions? Thanks
