Hi, I have just installed a D-LINK DNS-320L NAS in my local network.
Trying to connect it on Volumio I get this message in the attached picture.
Please help with some clues.
Thanks in advance
Ennio
Thanks in advance
Ennio
Double check that you have the shared directory on your NAS is correct. Have you also set the NFS permissions on your NAS to include the IP address of your Volumio device?
Add vers=1.0 in the advanced settings
I was having the same issue and Thank you… That worked for me
Thanks You, i’ve got the same issue when try to mount a D-LNIK 320L and solved by:
