Nas connect with nfs
hello i have volumio 3 and i can’t connect my nass drive (wd ex2 ultra) via nfs the volumio and nas is in the same network
  • You’ve enabled NFS on the WD?
  • You’ve setup a share for the music folder?
  • You’ve created a user tha can access this share?
  • You’ve the correct path to the shared folder?
Yes I have all enabled
then share screenshots of:
  • the setup you did in Volumio
  • The file path you use in windows to access the share
I meant this overview:
the windows screenshot is not the full path to the folder, just the root.
I would expect something like \\<ip>\<sharename>
i try like u but show me this
Please open a terminal seesion with Volumio and enter and paste the results:
smbclient -L 192.168.0.3
Just to be sure Volumio has a IP in the same subnet? (starting with 192.168.0.xxxx)
Can you setup a different count to access your music share.
this is my seting in my nas
i dont know how to acces terminal in volumio page
Using ssh:
But I see your mounting should be:
IT WORKED THX A LOT
