I have two Volumio devices set up in my network and can see both of them using myvolumio.org. When attempting to connect to either of these with the green play button, I get a continuing spinning logo but it never connects. I can connect with the .local or ip address so it’s manageable. This certainly doesn’t seem to be correct/desired behavior. Do I need to open ports or some other configuration?
MacOS, Safari browser. I tried Chrome with the same result. Note that I also tried from an external network with the same result.
I have done all of this (including factory reset) and it still behaves the same. I can access my devices with .local or IP address so it’s not a big deal. I simply expected to be able to access from the MyVolumio web page.
