I started trail period for MyVolumio Premium on fresh installation of Volumio 3.179. Got mail confirmation from paddle that trial started.
Despite this MyVolumio is not fully activated/unlocked. Have a look at attached screenshot.
How to get rid from these messages to buy Premium.
rost21A
December 26, 2021, 10:26pm
2
Have you completely restarted Volumio?
Yes, of course. Natürli. Several times.
Does a reset on factory defaults under system settings keep plan Premium?
How to make a factory reset without losing plan Premium?
Does a reset to factory defaults also reset the plan to free? Or is it possible to male a reset as/with plan Premium from the scratch?
chsims1
December 27, 2021, 9:20am
4
Have you logged out and back in to MyVolumio? I don’t think that doing a factory reset should alter your MyVolumio trial, but you should maybe check at:
Logging out and back in and reboot doesn’t help. I’ll check this with support. Thanks.
GeoRad
January 1, 2022, 1:30pm
6
I have the same issue, how do we get Volumio support on this.
Read back to the second post above your first?
