Mytek Stereo192-DSD USB2 on Raspberry Pi 4 / Volumio 4.119
Just leaving this here as a technical note for anyone who may eventually search for this rather unusual combination.
I am running a Mytek Digital Stereo192-DSD DAC via its USB2 input from a Raspberry Pi 4 running Volumio 4.119.
The original Linux driver is the old open-source mytekusb2 driver by Jurgen Kramer, based on Torsten Schenk’s TerraTec DMX 6Fire USB driver. I updated the driver for current Linux kernel APIs and fixed an issue in the multi-stage firmware loading process where USB re-enumeration could prevent the following firmware stage from being probed.
The resulting setup has been tested with:
  • Raspberry Pi 4
  • Volumio 4.119
  • kernel 6.12.74-v7l+
  • Mytek Stereo192-DSD USB2
  • 44.1 kHz and 192 kHz playback
  • sample-rate changes 44.1 → 192 → 44.1 kHz
Playback is stable and I have not seen XRUNs during the validation tests.
One old Mytek limitation remains: if the Raspberry Pi is rebooted while the already initialized DAC stays powered on, the DAC may come back with NO LOCK. Power-cycling only the Mytek restores normal operation; the Pi does not need another reboot.
The maintained source and documentation are here:
https://github.com/jantaplick/mytekusb2
The repository does not contain the proprietary Mytek firmware files. Those have to be supplied locally by the user.
This is not a support request and I am not really looking to start a larger discussion — I mainly wanted to leave the information somewhere searchable in case another owner of this DAC ever tries the same thing.
Just a small update on my Mytek Stereo192-DSD USB2 project.
After upgrading my Raspberry Pi 4 from Volumio 4.119 to 4.204, the Mytek USB2 interface initially stopped working because the kernel had changed from 6.12.74-v7l+ to 6.12.75-v7l+.
Fortunately, no further driver source changes were necessary. Rebuilding the existing patched snd_usb_mytek module against the exact new Raspberry Pi kernel sources and matching symbol versions was sufficient.
With Volumio 4.204, I successfully verified:
  • Automatic multi-stage firmware initialization
  • Stable playback at 44.1 kHz and 192 kHz
  • Sample-rate switching from 44.1 → 192 → 44.1 kHz
  • No XRUNs or new USB/PCM errors during playback
  • Automatic module loading after a clean reboot
Update – November 7, 2026: Volumio 4.239
I have now upgraded to Volumio 4.239, and this time the transition was much easier.
Volumio 4.239 still uses kernel 6.12.75-v7l+, so the previously compiled Mytek driver remains compatible. No rebuilding or source changes were required.
After the upgrade, the first firmware initialization attempt failed with a USB timeout (error -110) during the FPGA firmware upload. However, simply switching the Mytek off and on again resolved the issue.
The driver then completed its firmware initialization automatically:
Mytek USB firmware 3.1.35 loaded.
The Mytek USB2 interface is once again correctly recognized by ALSA, and the existing kernel module loads automatically.
Unfortunately, Qobuz is currently experiencing problems on my side, preventing me from completing the final playback tests with Volumio 4.239. I will therefore leave the 44.1/192 kHz playback validation for this particular release open for now.
The known warm-reboot limitation still applies: if the Raspberry Pi is restarted while the already initialized Mytek remains powered on, the DAC may need a power cycle before the USB2 interface becomes available again.
The maintained driver source and the latest validated package metadata are available in my GitHub fork:
The proprietary Mytek firmware files are intentionally not distributed in the public repository.
It’s nice to see that this older DAC can still be used through its original USB2 interface on current Volumio versions.
