Hi, I am suffering from that pesky bug that seems to cause my Qobuz to disappear from my home screen. It also disappears from the Plug in list and seems to take the Tidal plug in with it. It seems that the only way I have been able to get them to show up again is if I reset or reinstall my software. Is there a better solution for this?
I have started having this issue as well in the last month.
Details, details please. Device, Volumio version. Plugins installed.
Would you share some system logs please?
Preferable from a fresh reboot, with minimal steps to reproduce the problem
Not to the most tech savvy, but here goes:
Raspberry Pi 4 4GB
System Version: 2.882
Volumio mounted on microSD card; only thing on the card
Samsung 128 GB USB with local music
USB audio out to amp
Plugins:
Spotify 2.0.3
I think I possibly figured out what the issue is so not including a log for now.
Sources>Functionalities Control>Tidal Connect
Tidal Connect was deselected somehow. Reselected, rebooted and Qobuz came back.
Thank you for responding.
Same issue.
Settings / Sources / QOBUZ then re-enter login information worked for me
