My Volumio music player
I want to show you my Volumio music player.
The player is made with a TinkerBoard S and has 2 internal hard disks in which stores the musical library.
It is possible to access the internal hard disks through a frontal USB 3 port to make fast the library update. The LCD is a Waveshare 5" touch, there is also a mini wireless keyboard. The internal power supply are double: one power supply for the hard disks and the other for the Tinker Board, both are made with a toroidal transformer and a circuit based on a low dropout regulator LT3083 by Analog Devices.
The power button is connected to a RemotePi board for the on/off function with a software shutdown, this board also allows you to use an infrared remote control.
There is no internal DAC, the player is connected to an external Sabre ES9038Pro via USB. The audio performance is excellent.
The player has a gigabyte lan port and a wireless lan amplified with an external antenna.
That looks really nice!
Verstuurd vanaf mijn Moto G (5) met Tapatalk
