It is working very well.
Hardware:
- S-Case from AudioCreativ with 10 mm front and 330x120x230 (BxHxT)
- ASHATA 4xAluminum feet for HiFi devices
- external Powersupply 9V/5A
- Raspberry Pi4 with 4 GB with 64 GB SD Card
- Wimaxit 7" Touchscreen 1024x600
- Hifiberry DAC2 Pro
- AUDIOPHONICS PI-SPC REG Power Management Board
- Pushbutton with blue LED
- Rotary Encoder KY-040
- USB 3 Flash Drive Sandisk 256 GB for local music files
Software:
- Volumio 3.703
Plugins:
- AutoStart 3.0.4
- Rotary Encoder II 1.0.22
- PeppyMeter Screensaver 2.2.1
- Touch Display 3.4.0
Output:
- RCA L/R panel sockets
- 3.5 mm jack panel socket
- Ethernet RJ45 panel mount adapter
Functions:
- WiFi internet for radio
- Control Volumio with touch screen and/or mobile app
- Power on/off with push button
- Volume up and down with rotary encoder (normal push for play pause on/off)
- stores more than 11000 music files
Things do to:
- HDMI jack panel will be replaced with USB-A jack panel
