Volumio 3 working well on RPi4 with USB SSD T7 500GB and cheap Berhiger DAC.
When I access the T7 from a PC (Linux Mint), I see 26GB free space available when in fact when I plug in the T7 to the PC I see more than 400GB free. The T7 seems to be formatted as “FUSE”. Maybe I should reformat to FAT32 or something else. 5I think it makes sense to use a format compatible with both Linux and Windows.)
Could be the formatting, worth a try. Do you boot with the SSD? If so, Volumio would have required a LONG time to resize such an enormous partition before first use.
Thanks Simon
I boot with microSD 32GB
Maybe its a question of not understanding inodes?
See below
volumio@volumio:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p2 2.5G 425M 1.9G 19% /imgpart
/dev/loop0 364M 364M 0 100% /static
overlay 26G 18M 25G 1% /
devtmpfs 919M 0 919M 0% /dev
tmpfs 959M 0 959M 0% /dev/shm
tmpfs 959M 19M 940M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 959M 0 959M 0% /sys/fs/cgroup
tmpfs 959M 0 959M 0% /var/spool/cups
tmpfs 959M 32K 959M 1% /tmp
tmpfs 20M 656K 20M 4% /var/log
tmpfs 959M 0 959M 0% /var/spool/cups/tmp
/dev/mmcblk0p1 92M 54M 38M 59% /boot
/dev/sda1 466G 86G 381G 19% /media/T7
tmpfs 192M 0 192M 0% /run/user/1000
Ok, so the rest is visible under /dev/sda1. That 381 gig is usable for media storage if you want.
