I’ve got RPi2 (very happy with responsivness) and DAC-24192-ABR from Sellarz Audio Technology:
![](https://volumio.org/forum/resources/sellarz-ess9023-dac/330)
I took an vintage tube radio out of it’s case and I’m planing it as a case for my project:![](https://img0.etsystatic.com/036/0/7229402/il_570xN.563540638_6dow.jpg)
I’ll make custom front pannel for it. I’m wainting for Squeezebox Touch PSU (from diyaudio.com group buy).
I’ll post pics and thought on final product.
Front pannel will be made of plexi glass (not aluminium) as it’s cheaper and easier to work on. Aluminium has to be galvanized after cutting/brushing. Plexi is just fine after cutting on laser cutter. One process for engraving, drilling cutting …
I’ll stick to black and/or green (I’ll try to pick colors as similar as possible to combination on original front pannel). I’ll experiment with transparency …
This is mine: ![](http://mmc.bolha.com/2/image/189505/189913/Planica-ssn-2060_550e85596407c.jpg)
Next week I’ll start working with plexi. I’ll post a pic of a complete set of “raw” material & components before working on end product.
