My new Streamer-DAC project
Hi All!
My new Streamer-DAC
ESS9038Q2M DAC
Raspberry PI 3B+
2,8" TFT Display
What was your setup in Volumio for this display please? Was it just with the Touch Controller settings or did you also have to include some additional files?
Hi!
I use pre-configured image from her:
Choice this:
"Volumio 3.601
    ES9038 driver for hardware volume (kernel native)
    LCD Display support (Volumio version)
    LIRC pre-configured
    Switch filters via remote"
Thank you so much for your quick reply - I have downloaded that image and will see if I can get the LCD to work. Do you know what LCD Controller your LCD is/was using - ILI9341 or ST7789v ??
ILI9341 Contorller
Ah yes I see ILI9341 mentioned on the schematic. I’m using a Waveshare 2.4" LCD (SKU18366) that uses the ILI9341 controller but has a different pinout so I will have to try and figure out how to change the code if I can as my pinout is fixed. I have a Waveshare 2.8" LCD (SKU27579) but that too has a different pin out and uses the ST7789v controller.
