edited: replaced main script with new version
Hi
I recently built what I call a Christmas TV based on a Pi and Volumio.
When I came across this lovely TV (see pic) in a shop in downtown Zurich, Switzerland (where I live) I had the idea to beef it up with a Pi based musicplayer. The device was originally able to play about 5 christmas songs through a one inch speaker that was hooked up to a small circuit board.
The lovely 3D winter scenery ist illuminated with a number of led’s. A small train runs around in a circle with a tunnel. Just a tad kitschy but lovely. I call it Christmas TV.
So here is what I ended up with: I added a frontpanel with a number of pushbuttons and a backpanel with switches. The Pi is stacked with a HiFiBerry DAC+ and a Mini Jambox provides the sound output. It plays all my >200 xmas songs from Frank Sinatra, Elvis, Nat King Cole and many more (and plenty of Grateful Dead titles too). The mp3 songs are stored on a small usb stick.
The interface board carries all the resistors, the ADC chip für the volume and three connectors to the switches and led’s.
There are two python scripts (that could be combined into just one): one running several threads with callbacks for the pushbuttons. The other script initiates a shutdown if the shutdown pushbutton on the back panel is pressed. Before shutdown a 3 sec message is played: ‚thank you for listening, good bye‘.
The main scripts randomly plays a 6 sec. station identification: ‚all day, all night, xmas tv, stay tuned for more‘ that I recorded on my Mac. This and the whole thing is just for fun.
Greetings, Peter
Here are some pictures and the code.
System Schematics
Main Script
#!/usr/bin/python
# coding: utf-8
# Client for mpd-Server
# Programm starts 8 Threads
# waits für button click on four buttons - sets up three interrupt routines
# GPIO assignment:
# button 1 (GPIO8) : jump to next title in playlist
# button 2 (GPIO24) : jump to previuos title in playlist
# button 3 (GPI23) : jump to first title in playlist
# button 4 (GPIO15) : set mpd player to random mode (toggle)
# Switch on pot (GPIO14) for other uses, checked at start
# Led1 blinks as long as program runs
# Pressing any button blinks Led2 (red) twice for visual feedback
# Successful connection to mpd Server also blinks Led2 twice
# keyboard Interrupt is catched for testing purposes in Terminal, signals termination to all threads vi variable exitapp
# script waits also for random seconds to play station ID, suspends currentplaylist
# script also starts thread to read volume potentiometer and sets mpd volume accordingly
# code to read pot via chip MCP3008 is taken from Adafruits learning unit
# Analog Inputs for Raspberry Pi Using the MCP3008 (they call it bit banged).
# This script uses GPIO Pins 4/17/27/22 for CLK/DOUT/CS/CS
# Script is started via /etc/rc.local
# Pretty simple version found on the Volumio-Forum (nextbutton)
# Extended and adapted by Peter K. Boxler, December 2014
import RPi.GPIO as GPIO
import sys, getopt, os
import mpd
import time
import random
from threading import Thread
from math import floor
GPIO.setmode(GPIO.BCM)
buttonPinNext = 8
buttonPinPrev = 24
buttonPinStart = 23
buttonPinRandom = 15
potschalter = 14
led1=25 # green led blinks as long as script runs
led2=7 # red led blinks three times: acks button press
led3=9 # green led on= random play on off= random play off
# GPIO Pins for bit banged AD Converter (from Adafruit example)
SPICLK = 4
SPIMISO = 17
SPIMOSI = 27
SPICS = 22
debug=0
FALSE=0
TRUE=1
exitapp = FALSE
sleep_ping=30
randomstate=0
waitstatid_factor_long=100
waitstatid_factor_short=15
waitstatid=0 # wait time til next station ID play
potswitch=0 # status of pot switch at start time, check at start
global TEST_MPD_HOST, TEST_MPD_PORT, TEST_MPD_PASSWORD
TEST_MPD_HOST = "localhost"
TEST_MPD_PORT = "6600"
TEST_MPD_PASSWORD = "volumio" # password for Volumio / MPD
# ***** Function Parse commandline arguments ***********************
# get and parse commandline args
def arguments(argv):
global debug
try:
opts, args=getopt.getopt(argv,"dh")
except getopt.GetoptError:
print ("Parameter Error")
sys.exit(2)
for opt, arg in opts:
if opt in ("-h", "--help"):
print ("App mpd-client -----------------------------------")
print ("usage: mpd-client [-s -h]")
sys.exit(2)
elif opt == '-d': debug = 1
# get next song to be played
def get_nexid(mpd):
global debug
status = mpd.status()
for text in status:
if text=="nextsongid":
nexid=int(status.get(text))
if debug: print "Next SongID: %d" % nexid
return(nexid)
# lower volume from current value to zero, returns current value
def lower_volume(mpd):
global debug
for text in status:
if text=="volume":
curvol=int(status.get(text))
if debug: print "Current Volume: %d" % curvol
volume=curvol
if debug: print "Decreasing Volume"
while TRUE:
volume=volume-10
if volume<0:
volume=0
mpd.setvol(volume)
if debug: print "Volume ist NULL"
break
mpd.setvol(volume)
time.sleep(1.5)
return(curvol)
def connect_mpd():
# Connect with MPD (music player daemon)
global debug
connected = False
retry_count=3
i=1
while connected == False:
connected = True
try:
client.connect(TEST_MPD_HOST, TEST_MPD_PORT)
except SocketError as e:
connected = False
if connected == False:
if debug: print "Couldn't connect. Retrying"
i=i+1
if i > retry_count:
return(9)
time.sleep(3)
if debug: print("Connected to MPD-Server")
return(0)
# read SPI data from MCP3008 chip, 8 possible adc's (0 thru 7)
def readadc(adcnum, clockpin, mosipin, misopin, cspin):
if ((adcnum > 7) or (adcnum < 0)):
return -1
GPIO.output(cspin, True)
GPIO.output(clockpin, False) # start clock low
GPIO.output(cspin, False) # bring CS low
commandout = adcnum
commandout |= 0x18 # start bit + single-ended bit
commandout <<= 3 # we only need to send 5 bits here
for i in range(5):
if (commandout & 0x80):
GPIO.output(mosipin, True)
else:
GPIO.output(mosipin, False)
commandout <<= 1
GPIO.output(clockpin, True)
adcout = 0
# read in one empty bit, one null bit and 10 ADC bits
for i in range(12):
adcout <<= 1
if (GPIO.input(misopin)):
adcout |= 0x1
adcout >>= 1 # first bit is 'null' so drop it
return adcout
def blink_led1(): # blink led coninuosly when program runs
while not exitapp:
for i in range(3):
GPIO.output(led1, True)
time.sleep(0.2)
GPIO.output(led1, False)
time.sleep(0.8)
def blink_led2(anzahl,laenge): # Visual feedback if button pressed and connected
for i in range(anzahl):
GPIO.output(led2, True)
time.sleep(laenge)
GPIO.output(led2, False)
time.sleep(0.1)
def my_callback_nx(channel):
global starttime, waitstatid
if debug: print "Pin Falling: %d" % channel
time.sleep(.2) # confirm the movement by waiting 1 sec
if not GPIO.input(buttonPinNext): # and check again the input
if debug: print("ok, pin ist tief!")
ret=client.next()
blink_led2(2,0.1)
# button next serves another purpose:
# if nextbutton is pressed within 20 seconds after start the wait factor for station ID is set to small (for testing and demo)
if starttime:
timenow = time.time()
elapsed = floor(timenow - starttime)
if debug: print "%s seconds elapsed" % elapsed
if elapsed < 20:
waitstatid=waitstatid_factor_short
print "Waittime is now short %s", waitstatid
starttime=0 # do this only once
def my_callback_pr(channel):
if not GPIO.input(buttonPinPrev): # and check again the input
client.previous()
blink_led2(2,0.1)
def my_callback_start(channel):
if not GPIO.input(buttonPinStart): # and check again the input
client.play(0)
blink_led2(2,0.1)
def my_callback_rd(channel):
global randomstate
if not GPIO.input(buttonPinRandom): # and check again the input
if randomstate:
GPIO.output(led3, False)
client.random(0)
randomstate=0
else:
GPIO.output(led3, True)
client.random(1)
randomstate=1
blink_led2(2,0.1)
def connection_status():
# pings server every 60 seconds and prints "pinging" (if debug is specified).
global sleep_ping, exitapp
while not exitapp: # main thread gives terminate signal here
if debug: print "Connection: pinging the server"
client.ping()
wait=sleep_ping
while wait > 0:
time.sleep(3)
wait=wait-3
# if debug: print "Connection: Waiting 3 seconds"
if exitapp: break
client.close() # we need to terminate
if debug: print "-->Thread Connection terminating..."
sys.exit(0)
def button_nx():
global exitapp
GPIO.add_event_detect(buttonPinNext, GPIO.FALLING, callback=my_callback_nx, bouncetime=300)
while not exitapp:
time.sleep(1)
pass # pass ist leer statement
time.sleep(1)
if debug: print "-->Thread NEXT terminating..."
sys.exit(0)
def button_pr():
global exitapp
GPIO.add_event_detect(buttonPinPrev, GPIO.FALLING, callback=my_callback_pr, bouncetime=300)
time.sleep(1)
time.sleep(1)
if debug: print "-->Thread PREVIOUS terminating..."
sys.exit(0)
def button_st():
global exitapp
GPIO.add_event_detect(buttonPinStart, GPIO.FALLING, callback=my_callback_start, bouncetime=300)
time.sleep(1)
time.sleep(1)
if debug: print "-->Thread START PL terminating..."
sys.exit(0)
def button_rd():
global exitapp
GPIO.add_event_detect(buttonPinRandom, GPIO.FALLING, callback=my_callback_rd, bouncetime=300)
time.sleep(1)
time.sleep(1)
if debug: print "-->Thread RANDOM terminating..."
sys.exit(0)
# function (thread) to read pot and set volumne
def read_pot():
global exitapp, debug, potswitch
# 10k trim pot connected to adc #0
potentiometer_adc = 0;
if potswitch: return # do not ajust volume if switch was on at start (for testing jitter)
last_read = 0 # this keeps track of the last potentiometer value
tolerance = 10 # to keep from being jittery we'll only change
# volume when the pot has moved more than 5 'counts'
while not exitapp: # loop til main threads signals termination
# we'll assume that the pot didn't move
trim_pot_changed = False
# read the analog pin
trim_pot = readadc(potentiometer_adc, SPICLK, SPIMOSI, SPIMISO, SPICS)
# how much has it changed since the last read?
pot_adjust = abs(trim_pot - last_read)
if ( pot_adjust > tolerance ):
trim_pot_changed = True
if ( trim_pot_changed ):
if debug:
print "Pot tolerance %d before %s change %s new %s" % (tolerance, trim_pot, (trim_pot - last_read), last_read)
set_volume = trim_pot / 10.24 # convert 10bit adc0 (0-1024) trim pot read into 0-100 volume level
set_volume = round(set_volume) # round out decimal value
set_volume = int(set_volume) # cast volume as integer
if debug: print 'Volume new = {volume}%' .format(volume = set_volume)
client.setvol(set_volume)
# save the potentiometer reading for the next loop
last_read = trim_pot
# hang out and do nothing for a half second
time.sleep(1.5)
# waits randoms seconds and plays station ID
# decreases volume , adds station ID file (mp3) to current playlist, plays it and then deletes it from playlist
# resumes play at next song
def station_id():
global exitapp, waitstatid
waitrandom=random.randint(5, 15)
i=1
# waitstatid can change while running, so loop is a bit crooked.
while True:
i=i+1
waittime=waitrandom*waitstatid-(i*4)
if waittime > 2:
time.sleep(4)
if debug: print "StationID: waiting for %d seconds, factor %s" % (waittime,waitstatid)
else: break
if exitapp: break
# ret=connect_mpd(client)
# if debug: print "Werbung Return from Connect MPD: %d" % ret
if exitapp: break
nxid=get_nexid(client) # nächstes stück der Playlist holen (ID), wird nach Station ID gespielt
ident=client.addid("werbung_1.mp3") # werbung.mp3 zur aktuellen playlist addieren und ID merken
if debug: print "Station_ID ID: %s" % ident
cur_vol=lower_volume(client) # Volume vermindern auf Null, aktuellen Wert vorher speichern
client.setvol(cur_vol) # Volume wieder erstellen
if debug: print "Station_ID: Volume reset to %d" % cur_vol
client.playid(int(ident)) # Play Station ID spielen
time.sleep(9) # warten bis gespielt
client.playid(nxid) # vorher gespeichtertes nächstes Stück spielen
client.deleteid(int(ident)) # Station ID mp3 entfernen aus der Playlist
time.sleep(5)
# client.disconnect()
# if debug: print " Disconnected from MPD"
if debug: print "-->Thread Station-ID terminating..."
sys.exit(0)
def termplay(): # function not used here
volume=60
for i in range(15):
volume=volume-15
time.sleep(0.3)
time.sleep(3)
print "Set Volume to %d" % volume
client.setvol(volume)
time.sleep(3)
# --------- MAIN --------
arguments(sys.argv[1:]) # get commandline arguments
#GPIO.cleanup(buttonPinNext) # cleanup GPIO Pins
#GPIO.cleanup(buttonPinPrev) # cleanup GPIO Pins
#GPIO.cleanup(buttonPinStart) # cleanup GPIO Pins
GPIO.setwarnings(False)
GPIO.setup(led1, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(led2, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(led3, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(buttonPinNext, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(buttonPinPrev, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(buttonPinStart, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(buttonPinRandom, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(potschalter, GPIO.IN, pull_up_down=GPIO.PUD_UP) # switch on Potentiometer
# set up the SPI interface pins (ADConverter)
GPIO.setup(SPIMOSI, GPIO.OUT)
GPIO.setup(SPIMISO, GPIO.IN)
GPIO.setup(SPICLK, GPIO.OUT)
GPIO.setup(SPICS, GPIO.OUT)
time.sleep(1)
# setup mpd Client Object
client = mpd.MPDClient()
ret=connect_mpd() # connect to MPD server
if ret==9:
if debug: print "Could not connect to MPD"
sys.exit(2)
blink_led2(2,0.5)
# reset random play
client.random(0)
# start play with volume 60%
client.setvol(60)
# clear current playlist
client.clear()
if debug: print "Playlist cleared"
# check the sitch on the pot: that determines the playlist that we start with. Playlist are predefined
if GPIO.input(potschalter): # Potswitch it off (ganz links gedreht)
# start playing using playlist Blues-1
client.load("Blues-1")
if debug: print "Blues-1 loaded"
else:
# start playing using playlist Dead-1
client.load("Dead-1")
if debug: print "Dead-1 loaded"
potswitch=1 # potswitch status 1
# start with first song in playlist
client.play(0) # play first song in playlist
waitstatid=waitstatid_factor_long # that can be changed bei pressing the next button with 20 sec after boot.
starttime = time.time() # save start time
if debug:
print "MPD-Version: %s" % client.mpd_version
print "Wait Factor for Station ID is %s" % waitstatid
# create and Start Threads
connect_thread = Thread(target = connection_status)
button_nx_thread = Thread(target = button_nx)
button_pr_thread = Thread(target = button_pr)
button_st_thread = Thread(target = button_st)
button_rd_thread = Thread(target = button_rd)
station_id_thread = Thread(target = station_id)
led1_thread = Thread(target = blink_led1)
volume_thread = Thread(target = read_pot)
connect_thread.start() # thread to keep connection to mpd
button_nx_thread.start() # thread to watch for NEXT button
button_pr_thread.start() # thread to watch for PREVIOUS button
button_st_thread.start() # thread to watch for START Playlist button
button_rd_thread.start() # thread to watch for RANDOM PLAY button
station_id_thread.start() # thread to play station ID at random intervalls
led1_thread.start() # thread to blink green led
volume_thread.start() # thread to read pot and set volume
# Main thread goes into loop (wait for ctrl-C)
# ctrl-C bloss für Tests im Vorground !!
# posit
try:
while True:
time.sleep(3)
if debug: print "Main thread waiting"
# somebody wants us to stop doing what we are doing...
except KeyboardInterrupt:
# cleanup
blink_led2(5,0.1)
exitapp = TRUE # signal exit to the other threads, they will terminate themselfs
if debug: print "Main: exitapp Signaled"
raise
if debug: print "Main: Terminating, waiting 6 seconds"
GPIO.cleanup(led1) # cleanup GPIO Pins
GPIO.cleanup(led2) # cleanup GPIO Pins
GPIO.cleanup(led3) # cleanup GPIO Pins
GPIO.cleanup(SPIMOSI)
GPIO.cleanup(SPIMISO)
GPIO.cleanup(SPICLK)
GPIO.cleanup(SPICS)
time.sleep(6) # wait for other threads
client.disconnect()
sys.exit(0)
# The End
Shutdown script
#!/usr/bin/python
# coding: utf-8
# Pi Soft Shutdown Script
# Initiate Shutdown, Play Bye Bye song before shutting down
# Script started at boot via /etc/rc.local
# Peter Boxler, Dezember 2014
# Import the modules to send commands to the system and access GPIO pins
from subprocess import call
import RPi.GPIO as gpio
from time import sleep
import sys, getopt
from mpd import MPDClient
# Define variables to store the pin numbers
# for my TV Project
soft_shutdown_pin = 11 # Default pin for Pi Supply is 30 (war 7/16)
soft_shutdown_led = 10 #for visual feebdack ---->
#from time import sleep
var=1
global debug
debug=0
global debug
try:
sys.exit(2)
print ("App softshut-mytv -----------------------------------")
print ("usage: softshut-mytv [-s -h]")
sys.exit(2)
# Define a function to run when an interrupt is called
def shutdown():
# call(['shutdown', '-hP','+0.5'], shell=False)
if debug: print "sleeping 4 secs"
sleep(4) # zeit geben den prozessen
if debug:
print "Shutdown here"
sleep(3)
else:
if debug: print "Doing Shutdown now"
call('halt', shell=False)
pass
def blink_led(): # blink led 3 mal bei start und bei shutdown
for i in range(3):
GPIO.output(soft_shutdown_led, True)
sleep(0.2)
GPIO.output(soft_shutdown_led, False)
sleep(0.2)
def my_callback(channel):
if debug: print "shutdown Pin Falling: %d" % channel
sleep(1.5) # confirm the movement by waiting 1 sec
if not GPIO.input(soft_shutdown_pin): # and check again the input
if debug: print("ok, shutdownpin ist tief!")
blink_led()
client = MPDClient() # create client object
client.timeout = 10 # network timeout in seconds (floats allowed), default: None
client.idletimeout = None # timeout for fetching the result of the idle command is handled seperately, default:$
if debug: print "Return from Connect MPD: %d" % ret
lower_volume(client) # lower Volume to zero
client.setvol(60) # set Volume to 60% for bye bye Song (Text)
ident=client.addid("end_tv.mp3") # load mp3 into playlist, store song id
if debug: print "Endplay ID: %s" % ident
client.playid(int(ident)) # play bye bye song
sleep(6)
client.deleteid(int(ident)) # delete song from paylist
client.disconnect() # disconnect from mpd
shutdown() # initiate Pi shutdown
def connect_mpd(mpd):
# Connect with MPD
global debug
connected = False
retry_count=3
i=1
connected = True
try:
mpd.connect(TEST_MPD_HOST, TEST_MPD_PORT)
connected = False
if debug: print "Couldn't connect to MPD. Retrying"
i=i+1
if i > retry_count:
return(9)
sleep(3)
return(0)
global debug
for text in status:
if text=="volume":
volume=curvol
if debug: print "Volume decreasing"
while True:
volume=volume-10
if volume<0:
volume=0
mpd.setvol(volume)
break
mpd.setvol(volume)
sleep(1.5)
if debug: print" Running with debug on"
# setup GPIO Pins
GPIO.setup(soft_shutdown_pin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(soft_shutdown_led, GPIO.OUT, initial=GPIO.LOW)
sleep(5)
blink_led()
# add callback für Shutdown Pushbutton on Pin
GPIO.add_event_detect(soft_shutdown_pin, GPIO.FALLING, callback=my_callback, bouncetime=300)
# you can continue doing other stuff here
while True:
sleep(1)
# End of Program
