Hi everyone,
I am using a Musical Fidelity MX-Stream with Volumio. So far so good.
Unfortunately the MX user interface for Tidal is very ugly - even through Volumio.
I decided to go via Tidal Connect, something that according to MF should work fine.
However MX does not appear in the list of devices when I press the relevant button in the Tidal app.
I am using latest software versions in all components.
Any idea would be very appreciated.
Many thanks.
Dinos
Hi @dconstan61
I’m just another fellow user.
Have you logged into your Tidal account within Volumio?
I use Qobuz Connect and even if the Qobuz Connect option is on I needed to log into Qobuz with Volumio for it to appear.
Hi, Thank you for the reply. I am afraid that I do not understand / know how to login to Tidal within Volumio. Can you please explain?
I am using Volumio in my iPhone to control my MX Streamer. Many thanks.
Dinos
