I´ve tried Volumio in the past but decided then to go for Runeaudio. Now Volumio2 is out and I wanted to check it out.
So I installed version 2.041 on a RPi3 with the Spotify and display plugins. The I mounted my NAS with NFS and started my music scan.
Scanning is very slow and I noticed a considerable drop in network performance.
Normaly, when I do a network speed test with iperf3, I get close 1 Gbits/sec. But with Volumio2 scanning, network performance drops to 14 Mbits/sec. It´s not that Volumio uses 980 Mb/s because the pi only has a 100 Mb/s lan port.
I checked volumio with journalctl -f but there is nothing special, only that it scans slow.
I tried this also with a RPi2 and different cables all with the same result.
Is there anyone with the same problem or anyone who has a clue?
Michelangelo, I am noticing a number of similar posts about library scanning. You said on Github earlier that this was a mpd/fmmpeg problem. Using your code to disable ffmeg for mpd, results in a big soft crash on Odroid C2. This is noted elsewhere on the forums, but gkkpch reports that he has used it successfully in the past. I’m a bit confused about inconsistencies here.
I would be interested to understand why this seems to be a problem on Odroid C2 and Cubox (assuming here that it is the same problem) but it doesn’t show itself on RPi … just showing my ignorance obviously
My assumption here is that debian package is somehow broken (or conflicts with the particular version of mpd that we compiled).
At this point I guess the best solution is skipping to mpd 20.2 …
