HW: RaspberryPi CM4 with IOboard, Sandisk Extreme Portable SSD 1TB
Volumio Version: Volumio3 official release + update to newest version
I am using Sandisk Extreme SSD 1TB formatted EXT4 file system and connected via USB as my music library. However everytime I connect the SSD to Volumio installed Raspi, my music library gets wiped out. I can see Volumio starts updating MDP database, then it erases the music files and folders. This happens not once but 5th time until now.
The same behavior happened with Buster Betaâs also.
As I searched this community forum, I found similar report but little bit different case.
If more information is needed please guide me what and how I can provide.
you better have a copy of it and donât connect it with a fresh install,
i donât know how it effects on updates but better be safe then lose it again.
Got it.
I donât want to go back to my Volumio+NAS set up.
Every music files I have is ripped from the CDs I have. I have copies on my computer anyway. Maybe I should try with ready only file permissions on external drive.
Thanks again Mr. dvo
Is it every time you connect an external drive this happens (even for a up and running system) or was it when you installed Volumio and had the drive connected?
Because if it is the first, then itâs a new issue!
I also donât what âwith a new install remove external drivesâ means. Does it mean remove external drives before the update and then add them back after the update?
@songskim As you seem to be able to reproduce the issue, we would really be interested to see a log of this happening.
Could you share some system logs please?
Preferable from a fresh reboot, with minimal steps to reproduce the problem with the ssd being wiped:-)
There were previous reports, but nobody has yet been able to reproduce this, so your help is very important to us and much appreciated.
Though your issue may not be exact the same as was reported before during a Volumio 2 to Volumio 3 OTA update, it might give us an idea what might be happening.
As a âMIT graduateâ you should also be able to search the forum, especially using the banner at the top of the forum pages. It will explain what previous reports were about
Community members are not here to repeat posts that were already made.
I must be searching the wrong way because all I see is âbrokenâ software mixer topics and no software mixer âqualityâ issues. My search term is simply âsoftware mixerâ and my intent was to search all of community forums.
One example of a post on the quality question would be appreciated. Iâve scrolled past dozens that have nothing to do with quality of working SW mixer configs, only broken SW mixers⊠thatâs not my issue.
I added âdtoverlay=dwc2,dr_mode=hostâ to /boot/config.txt =>For the system log you want, I know I should keep the minimal initial installation but this is need for Raspi CM4 IOboard to get USB ports get enabled.
I configured the system via WebUI configuration
I connected the SSD
It scanned music files but âDID NOT DELETE THE FILESâ
I do not know what different things I did before but the music library is staying.
I installed youtube plugin and my personal radio plugin last time. This time, I have not installed them yet.
There is another difference. I copied music files from my PC to the SSD and connected to Volumio. THIS TIME, I changed the folders and files to 755 permissions before I connected it to Volumio. They are mounted with ownership of âvolumio:volumioâ and 755 file permissions.
Sorry I could not reproduce the problem yet.
I copied part of the system log before I factory reset. Here is the part of the system log thatâs suspicious before I did factory reset. One can probably see it was updating music library then âremovingâ
(Below is part of the log and the whole log is at âhttp://logs.volumio.org/volumio/Evx3oUl.htmlâ)
Best(Folk)/ĂȘÂčâŹĂȘÂŽâĂŹâ - Best Disc 2.ape Dec 25 04:56 :
update: added USB/Sandisk_1TB/Music/ĂȘ°âŹĂŹĆĄâ/ĂȘÂčâŹĂȘÂŽâĂŹâÂ
Best(Folk)/ĂȘÂčâŹĂȘÂŽâĂŹâ - Best Disc 1.ape Dec 25 04:56 :
exception: Failed to open
/var/lib/mpd/music/USB/Sandisk_1TB/lost+found: Permission denied Dec
25 04:57 : client: [2] opened from local Dec 25 04:57 : client: [2]
closed Dec 25 04:57 : exception: Failed to open ZIP file
/var/lib/mpd/music/USB/Sandisk_1TB/Music/Classical/Mozart/Mozart
complete Volume 4 - Chamber Music,Violin Sonatas,Church
Sonatas/Volume 4(CD8) Violin Sonatas KV 6-9.zip Dec 25 04:57 :
Sonatas/Volume 4(CD9) Violin Sonatas KV26-31 Variations 359,360.zip
25 04:57 : client: [3] opened from local Dec 25 04:57 : client: [3]
closed Dec 25 04:57 : update: removing
USB/Sandisk_1TB/Music/Pop/Adele (2008) 19/09 - Make You Feel My
Love.flac Dec 25 04:57 : update: removing
USB/Sandisk_1TB/Music/Pop/Adele (2008) 19/08 - Right as Rain.flac Dec
25 04:57 : update: removing USB/Sandisk_1TB/Music/Pop/Adele (2008)
19/07 - First Love.flac Dec 25 04:57 : update: removing
USB/Sandisk_1TB/Music/Pop/Adele (2008) 19/06 - Melt My Heart to
Stone.flac Dec 25 04:57 : update: removing
USB/Sandisk_1TB/Music/Pop/Adele (2008) 19/05 - Crazy for You.flac Dec
19/04 - Cold Shoulder.flac Dec 25 04:57 : update: removing
USB/Sandisk_1TB/Music/Pop/Adele (2008) 19/03 - Chasing Pavements.flac`
I will trace carefully and report it better if it happens again.
Would people please stop reporting âme tooâ, this does not help at all, actually it is absolutely useless, whereas they possibly have information that would help finding a pattern.
Devs will love to get system information like platform (PI, Tinker, x86), USB disk make and model, in case of a self-installed one, the make of the usb-to-sata case. Also give details about the type of disk ssd/hdd and its size.
