Hello @devgianlu@DED
Have you find time to take a look on previous logs ?
It is much better with this fix, but still stopping . I guess you are on good track
after I have flashed the new sw , The timing I have written in the previous message ,
It was in the afternoon , 14:00 PM something lke that and stopped after 3 4hrs …
Hello ,
I have the latest version 3.874 and the behaviour appear again , meaning the music is stopped then I have to disable and enable the cast to …
when music is stopped . http://logs.volumio.org/volumio/X1tnt8P.html
after disable and enable the cast to : http://logs.volumio.org/volumio/7cGroIv.html
So , from last post to understand that the fix is only in v4 ?
Hello ,
I have updated the plug-in, the music is not stopped, but on the screen I see only the background changing , spectrum is not started , after I select a file when should I press download ? I have pressed only update list after I have selected a file them apply in the bottom
You have to select the ‘family’ on the top selector. Apply.
On the second selector, choose the spectrum you want to use.
This is not different from previous version.
You may have to reboot after you update
I want to mention that I have listen to a chromcast audio speaker , the display is on other room on my streamer ,
@balbuze I have observed that the spectrum iss not shown when cast to is activated , but strange that the background ia shown … maybe or would be ok not ribatatt at all to add a note that spectrum is shown only when music is played locally not to chrome cast audio …
At least the music ia noir stopped anymore when the plug-in is activated
I have observed a big improvement ok volumul v4 . Cast feature is working flawless stopping , restarting etc , all is working as should be . When press play or cat to … music is started .
