Hello all,
Really enjoying my 2 volumio2 raspberry pi with DAC players. Noticed the multiroom addition in the main screen, but not sure how it is meant to work: is this only so you can switch within 1 webpage to the other player and manage it, or is it meant as a multiroom that syncs the same audio played to more then 1 player?
Logged in with ssh and noticed the snapserver and snapclient binaries and also the mpd entry for the /tmp/snapfifo audio_output, so I would guess it should be possible to sync the audio output to both players somehow.
I do not understand how to switch from standalone to the multiplayer mode though: do I need to start the snapserver and snapclient myself, and do i need to change the configuration somewhere?
Hope someone can help or give me some guidance.
Regards!
) via snapcast, as you pointed out above.
