Multiroom sync - Hardware latency doesnt affect delay
Hi!
Setup is a RPI4b running Volumio v3.703 (main) and RPI3 running the same (client).
I setup multiroom and it works but there is an audible delay.
Set the Buffer (all clients) to 1500ms and stream buffer to 50ms.
Now, By ear, the delay on a 4/4 metronome track is circa 100-200ms with the RPI3 behind, after. the RPI4b.
The problem comes that no matter what settings I type into the hardware latency on the RPI4b (main) the sound never comes into sync.
Infact I even type in 1000 and the sound is exactly the same (when the down beat on the 4/4 should now be audibly behind the normal beat on the metronome) and same for -1000.
ONe thing I notice too is that when the seting is changed it causes a pause in the client/main sound but doesnt pause the other side, so I have been typing in a value, then restarting the stream each time; no change.
I even thought I may enter in a negative value on the main side; no change.
positive value on the main side, no change.
change on the client side; no change.
no matter what I do its the same delay each and every time?
What am I missing here?
