So I moved to Volumio from Moode for the multiroom.
Got it setup.
1x Asustore holding the flac/mp3 music in varying 192 to 44 khz at 16 - 24 bit (from my production days, I kept my hi res masters).
1x pi 4b feeding an Ifi dac.
1x pi 3b feeding another ifi dac.
I group the 3b to the 4b and play on the 4b (master), music plays on the 3b (slave) as expected.
The problem is the 3b (slave) ALWAYS displays the source as multiroom (correct) but 48khz and 24bit. that is to say if I play 92khz source flac at 24 bit on the 4b it will still play multiroom 48khz 24 bit on the slave 3b.
The Ifi also has a silly little colour changer for the sample rate and, whilst a gimmic I agree, it does switch colours when I play 92khz flac directly. when playing multiroom on the slave it indicates 48khz even if the master 4b is playing 92khz.
I use DSP parametric EQs on the slave, turning this off still causes the 48khz resample.
So main questions:
- Is multiroom slave always resampling up from 44 and down from 96 to 48khz before sending to the slave?
- Is DSP parametric EQs on the slave causing the resample or is it a part of the multiroom?
- how can I get Volumios out the box to play bit perfect/un-resampled audio to the slave?
- if it cant be done out the box, is installing snapcast the way to do this? Is there a guide?
- if snapcast is the way, is it gapless between tracks on volumio?
Bonus:
a) Sometimes the 3b seems to ‘stick’ on screens on multicast. so it will play the audio, display new album art when swithcing tracks, but wont update the play time or prgress. Bug I assume?
b) asked in the FAQ I know, but could volumio please remember the groupings I setup power power off?
Thank you for your time and the great product!
