Multiroom Devices not reachable with Volumio 2.029
They will be shown but if You choose one it´s loading endless without success.
The version before it worked.
Same issue.
Ciao
Franco
Inviato dal mio iPhone utilizzando Tapatalk
I do have the same problem when I switch Multiroom devices, but I’m not sure it came with 2.029 (Is been around in previous versions too)
Have 2 devices a Rpi3 and a Pc with X86.
Just a Note: Can’t access the x86 with volumio.local , I must use Ip address!
When using the Rpi and switch Multiroom device from the Rpi to the X86 I get the spinning wheel
When I use the X86 and switch to the Rpi it works fine but when I switch back to the X86 I get the spinning wheel
sudo journalctl -f from the x86 (sk4) when switching to the Rpi (sk3) and back
permitted by applicable law.
volumio@sk4:~$
volumio@sk4:~$ sudo journalctl -f
-- Logs begin at Sat 2016-11-19 12:16:21 UTC. --
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521762] parsing response...
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521763] ControllerMpd::parseTrackInfo
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521764] ControllerMpd::pushState
Nov 19 13:52:01 sk4 volumio[903]: info: CoreCommandRouter::servicePushState
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521765] CoreStateMachine::syncState
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521766] CorePlayQueue::getTrack 0
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521766] Received update from a service different from the one supposed to be playing music. Skipping notification.Current webradio Received mpd
Nov 19 13:52:01 sk4 volumio[903]: info: [1479563521767] ------------------------------ 346ms
Nov 19 13:52:02 sk4 sudo[3906]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Nov 19 13:52:02 sk4 sudo[3906]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Nov 19 13:52:19 sk4 volumio[903]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Nov 19 13:52:19 sk4 volumio[903]: info: CoreCommandRouter::volumioGetState
Nov 19 13:52:19 sk4 volumio[903]: info: [1479563539989] CoreStateMachine::getState
Nov 19 13:52:19 sk4 volumio[903]: info: [1479563539990] CorePlayQueue::getTrack 0
Nov 19 13:52:20 sk4 volumio[903]: [1479563539991] ---------------------------- Client requests Volumio state
Nov 19 13:52:20 sk4 volumio[903]: info: [1479563539994] Listing playlists
Nov 19 13:52:20 sk4 volumio[903]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Nov 19 13:52:20 sk4 volumio[903]: Plugin multiroom or method getMultiroom not found
Nov 19 13:52:20 sk4 volumio[903]: [1479563540013] ---------------------------- Client requests Menu Items
Nov 19 13:52:20 sk4 volumio[903]: info: [1479563540014] InterfaceWebUI::pushState
Nov 19 13:52:20 sk4 volumio[903]: info: [1479563540030] ------------------------------ 41ms
Nov 19 13:52:20 sk4 volumio[903]: info: [1479563540052] ------------------------------ 39ms
Nov 19 13:52:20 sk4 volumio[903]: info: No input data
Nov 19 13:52:21 sk4 mpd[657]: errno: Failed to open 'USB/volumiodata/dyn/var/lib/samba/winbindd_privileged': Permission denied
Nov 19 13:52:21 sk4 mpd[657]: errno: Failed to open 'USB/volumiodata/dyn/var/lib/samba/private/smbd.tmp/msg': Permission denied
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541434] ControllerMpd::sendMpdCommand status
Nov 19 13:52:21 sk4 volumio[903]: info: Mpd Status Update: update
Nov 19 13:52:21 sk4 volumio[903]: [1479563541435] ---------------------------- MPD announces state update
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541436] sending command...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541438] ControllerMpd::getState
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541438] ControllerMpd::sendMpdCommand status
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541439] sending command...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541441] ControllerMpd::sendMpdCommand status
Nov 19 13:52:21 sk4 volumio[903]: [1479563541442] ---------------------------- MPD announces state update
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541443] sending command...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541445] ControllerMpd::getState
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541446] ControllerMpd::sendMpdCommand status
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541447] sending command...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541475] parsing response...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541476] parsing response...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541478] parsing response...
Nov 19 13:52:21 sk4 volumio[903]: info: [1479563541479] ControllerMpd::parseState
Nov 19 13:52:22 sk4 volumio[903]: info: Command Router : Notfying DB Updatefalse
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542134] ControllerMpd::parseState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542135] ControllerMpd::sendMpdCommand playlistinfo
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542136] ControllerMpd::parseState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542148] ControllerMpd::parseState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542149] ControllerMpd::sendMpdCommand playlistinfo
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542153] sending command...
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542155] sending command...
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542157] parsing response...
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542158] ControllerMpd::parseTrackInfo
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542158] ControllerMpd::pushState
Nov 19 13:52:22 sk4 volumio[903]: info: CoreCommandRouter::servicePushState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542159] CoreStateMachine::syncState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542160] CorePlayQueue::getTrack 0
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542160] Received update from a service different from the one supposed to be playing music. Skipping notification.Current webradio Received mpd
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542161] ------------------------------ 726ms
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542194] parsing response...
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542195] ControllerMpd::parseTrackInfo
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542196] ControllerMpd::pushState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542198] CoreStateMachine::syncState
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542199] CorePlayQueue::getTrack 0
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542200] Received update from a service different from the one supposed to be playing music. Skipping notification.Current webradio Received mpd
Nov 19 13:52:22 sk4 volumio[903]: info: [1479563542201] ------------------------------ 759ms
