I just installed 1.5 on a BBB and have noticed that the CPU usage for mpg123 is 90+ %, is this correct?
Whats really strange is the mpg123 uses more ( 98%) CPU when idle.
OK, after more troubleshooting, I found out the airplay will cause mpg123 to start, use 90% cpu and will not stop when airplay is no longer being used. If mpg123 continues to run at 90+ % it will cause Spotify to drop out occasionally.
