mpdlcd
Hello.
I installed the display support:
github.com/Saiyato/volumio-hd44780-plugin
I work, but I still have the display:
and nothig more. (Of course, the music plays)
in command I see:
volumio@volumio:~$ mpdlcd
File “/usr/local/bin/mpdlcd”, line 7, in
from mpdlcd import cli
File “/usr/local/lib/python2.7/dist-packages/mpdlcd/cli.py”, line 5, in
import configparser
ImportError: No module named configparser
volumio@volumio:~$
Can someone help me?
Hi! Yes, I also have such a question) Need help
[code]volumio@volumio:~$ Traceback (most recent call last):
import configparser
[1]+ Exit 1 mpdlcd --no-syslog[/code]
solved by installing python3 and python3-pip
sudo apt install python3 sudo apt install python3-pip sudo apt install python-mpd sudo pip3 install mpdlcd
SOURCE: forum-raspberrypi.de/forum/thre … porterror/
Volumio 3
Python 3.7.3
volumio@dac-salon:~$ sudo systemctl enable mpdlcd.service
mpdlcd.service is not a native service, redirecting to systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mpdlcd
insserv: warning: script ‘mpdlcd’ missing LSB tags
insserv: Default-Start undefined, assuming empty start runlevel(s) for script mpdlcd' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script mpdlcd’
update-rc.d: error: mpdlcd Default-Start contains no runlevels, aborting.
volumio@dac-salon:~$ systemctl status mpdlcd.service
● mpdlcd.service
Loaded: loaded (/etc/init.d/mpdlcd; generated)
Active: inactive (dead)
Docs: man:systemd-sysv-generator(8)
no chance to activate it!
