chsims1
February 10, 2022, 8:29pm
1
It seems that support for the BBC’s MPEG-DASH streams can be enabled in MPD by building with " --enable-libxml2". This would be very nice to include in the next custom MPD build.
opened 03:11PM - 17 May 19 UTC
feature
This issue is a feature request for [MPEG-DASH](
https://en.wikipedia.org/wiki/… Dynamic_Adaptive_Streaming_over_HTTP) audio support within Music Player Daemon.
> Dynamic Adaptive Streaming over HTTP (DASH), also known as MPEG-DASH, is an adaptive bitrate streaming technique that enables high quality streaming of media content over the Internet delivered from conventional HTTP web servers. Similar to Apple's HTTP Live Streaming (HLS)...
While most DASH streams are video streams, there are some audio-only streams, including from the BBC, which can be found [here](http://www.bbc.co.uk/radio/imda/imda_transports.xml).
If the project maintainers believe that this feature is outside the scope of the project or that demand is insufficient, and consequently close this issue, I will not be offended. Thank you for considering this feature request, and for all of your work on MPD.
